select settings dialogs using cursor
    DVDFab (UI/General) select settings dialogs using cursor
    I occassionally review my "settings" and it would be convenient to use the cursor and simply press the "down button" on the keyboard and cycle thru all the settings in the treeview. Unfortunately, only the mouse seems to work and I have to click on each setting in the tree to reveal its contents. I recall this is just a simple property of the tree diagram and the developer should be able to enable the cursor for use as an accelerator.
    Thanks for looking!
