It would be very nice indeed to have even a basic profile editor included with DVDFab's DVD to Mobile and File to Mobile so that after fiddling with all the options and finding what works best for your needs you could then save it with a name that makes more sense than XXX.default.
This would be especially useful should you want more than one custom profile under the same heading that you use for different source material. I don't know about all of you, but I've found that some movies and TV shows look just fine with a lot of compression while others (big action movies) need to have a much lower compression ratio in order to look good when played. It gets a bit tedious to have to change ALL the settings for each movie when it would be much simpler to select custom settings that you've set up in advance. For example; XBox.HighCompression, XBox.MediumCompression and XBox.LowCompression
On the same note, it would also be great if you could then export and share those profiles with others.
- Benjamin Franklin 1706-1790
