Higher audio bitrates
    Video Converter Higher audio bitrates
    It would be nice to have more options in bitrates for audio.
    I like to select the same bitrate as the source, especially when the codec is of the same overall quality as the destination one.
    For example, stereo can often go up to 256kbps, when it currently topped at 160bps.
    compressed 5.1 channels often go up to 768kbps, when it is currently topped at 512kpbs.
    Between the two, there is a difference that I can spot.
    Have you tried checking the "Copy Audio" box? You'll get the same audio as the source - if your device/software will play it.
      Yes, I'm aware of it.
      I use it when applicable, but it is far from covering every cases, especially with DTS tracks which my other applications doesn't support well.
      I do use a third party application to do the audio conversion, then use copy audio in dvdfab for the video conversion.
      Because of it, I can't use the Dvdfab's Ripper tools.
