Task Queue - Same Disc
    DVD Copy Task Queue - Same Disc
    When ripping a season disc it would be good to be able to add multiple items from the same disc (don't know if multidrive users can actually add multiple discs) to the task queue instead of just one, as each episode takes 15-20 mins to rip for me and a disc can hold 4-6 episodes this can mean being bound to my computer for nearly a couple of hours per disc
    Just chose the other titles pull down and check the other titles you want Fab to convert simple.
      I don't get a multiselect checkbox option only a radio single select?!?!
        If you want the whole disk use the clone mode and clone the whole disk.
        If your trying to rip to another format use the ripper you used copy mode.
