Cache BD contents on 2-pass for faster conversion
    BD Ripper (3D Plus) Cache BD contents on 2-pass for faster conversion
    It seems like that when performing 2-pass conversion that Fab actually goes over the disc twice.
    Would it be possible to add an option to cache the BD contents to local disk when performing the first pass, then to perform the second pass conversion using the cached contents on disk?
    This should drastically decrease the total conversion time since the local disk (HDD/SSD/etc.) is much faster than the BD drive.
    This will also reduce the chance of failing a rip due to BD-Rom I/O error caused by a physical defect since you're reading the disc one fewer time (in case you lucked out the first time).
    Hello,
    Thank you for your input. I have passed your message to our developers.
    Regards,
    Mona
