In the advanced conversion settings there is a drop-down menu regarding the amount of memory to use during conversion including standard, high speed, high quality and maximum, obviously in addition to the automatic one. But what difference is there between the others? But among others what difference is there
info
ok,Originally posted by Mona View PostThe memory amount used for the conversion
means how much memory the conversion will take, and what you set will affect the conversion speed.
because if I set automatic, maximum or high the notebook so to speak does not allow me to do other work instead on standard everything ok
