To further enhance our community services and improve user experience, we will be performing a comprehensive system upgrade of the DVDFab Forum on October 30, 2025 at 11:00am Beijing Time.
During this upgrade, all of your account information as well as previously posted threads and replies (Recently 12 months) will be fully migrated and preserved.
After the upgrade, you will be able to log in to the forum using your existing forum account or your DVDFab Member Center Account—no additional action is required.
When they are in ripper mode they can only use quicksync in decoding because by setting them in coding the quality is bad. The problem arises that by decoding the quicksync the GPU does not seem to work while if the imposed in coding this works but the result is bad in any case.
