overwrite decoding/encoding settings
    DVDFab (UI/General) overwrite decoding/encoding settings
    Hello, your link How to customize H.264/H.265 parameters (dvdfab.cn) it does not help much, and practically incomplete as well as when using the command line, what you write integrates without removing the basic setting from the log. So would you be able to add two examples, one for x264 and the other for x265, that are complete so that it is simple even for those who struggle? Thank you
