Create, edit and save compression options
    DVDFab (UI/General) Create, edit and save compression options
    I would like the ability to edit, create and save compression options so that I do not have to edit them all the time. X to Mobile lets me choose compression options which I routinely edit to 2 passes and make a video resolution change. I am getting tired having to edit this all the time. I would like to change it once and save it as the default. I would also like to be able to create more profiles so I can have them available from the pull down menu.
    Thanks,
    James McMann
    San Jose, CA. USA
