Requests For DVD 2 Mobile
    Not sure if these have been mentioned before.
    1. Drag and Drop to Queue.
    I want to select iso files in Windows Explorer and drag/drop them into the queue. Support cntl-a for the queue (this is a minor issue since multi-select is supported via shift and cntl).
    2. Support option to turn on/off cropping in the profile.
    3. Support for custom profiles from the command line. For example, I setup a modified HTC profile from gregiboy for my HTC TP2. It works from the GUI but the command line says HTC is not a valid profile.
    4. Improved Quality Control checks for command line. There have been numerous releases with the command line feature not working. It should be easy to setup a batch quality control script that runs through numerous conversions using the command line prior to release. For example, run 2-3 movies per profile. This could be spawned to numerous machines to make the runtime acceptable.
