Hi as an addition to the X to Mobile encoding menus (and perhaps an alternative option in DVD-DVD and BD-BD menus)
Add a slider for "Quality" level, as an alternative to bit rate and fixed file size...
Intention being to allow the system to optimises file size/bit rate based on the desired quality level.
Higher quality levels would enable more sophisticated motion estimation algorythms, b-frames, pyramidal b-frames, etc.... (ie lots more processing time in exchange for improved image and reduced file size)
Possibly linked to a "compatibility checkbox" - as some of the more sophisticated options in this area may not be compatible with all software/decoders.
thanks
thanks
