Stop PowerDVD from Playing while DVDFab is running
    Stop PowerDVD from playing DVDs and running while DVDFab is running.
    Fab has no control over PowerDVD, thats on your end. you need to open autorun to set what you want your computer to do after inserting a DVD.
      go into control panel and click hardware and sound then click autoplay and find poerDVD and change it to Choose a default or Ask me every time. It not a DVDFab problem as it your Autoplay on your computer
        Actually, if you're using Windows Vista you want to go to the Control Panel>Default Programs>Change Autoplay Settings. Scroll down to DVD Movie and change the selection to "Ask Me Everytime". Make this change for DVD movies and Enhanced DVD Movies. Click save and you're all set. The next time you insert a dvd you will be prompted to decide what program to open the disc with. Just make sure you don't check the check box that asks you if you want to make this the default application or you'll be back to where you started at.
