Upgraded my 2 yr Windows 7 system (E6850 Core Duo, 4 GB RAM) from a NVidia 8600GTX to the overclocked EVGA GTX460 ($179 at Amazon). Avatar Blu-Ray Extended took 4 hrs 20 mins with the original card and only 33 minutes to convert to DVD9 using BluRay Copy. The added CUDA cores certainly make a huge difference here- tremendous increase for the money.
NVidia EVGA GeForce GTX 460 Benchmark
Originally posted by jntwist View PostUpgraded my 2 yr Windows 7 system (E6850 Core Duo, 4 GB RAM) from a NVidia 8600GTX to the overclocked EVGA GTX460 ($179 at Amazon). Avatar Blu-Ray Extended took 4 hrs 20 mins with the original card and only 33 minutes to convert to DVD9 using BluRay Copy. The added CUDA cores certainly make a huge difference here- tremendous increase for the money.sigpic
A lot depends on the movie. If it requires compression it takes quit a bit longer. But in general, the GTX460 i installed made a huge difference on my my machine. On Blu-rays that don't require compression, main movie only, I can get it done in under an hour now, thats from inserting The BD to end of burn on the BDR. When I first started experimenting with ripping BDs almost 2 yrs ago the rip and encode alone could take as long as 8 hrs. I'd set it up before I went to bed and it'd still be chugging away when I got up in the morning.
