Yes me again, about that again.
I am ONLY posting this here in case it may help others, lock it if you want to.
Some time back I asked here about a different antivirus software to replace my McAfee that I was NOT happy with, and after much debate I went with the free MSE.
I had a LOT of trouble with it at first, removed and reinstalled it several times, all with a LOT of kind help from 90312.
It is now working perfectly, thanks to Steve and the fact we eventually worked out that I have CCleaner also, which is great and I love, however I did not think to check it thoroughly after installing MSE, and CCleaner by default was cleaning MSE every time I used it, including the history of scans etc.
Short story IF you have CCleaner, and why wouldn't you, make sure you check the settings after installing any new software, especially antivirus software.
