Blu-ray copy
    Software Blu-ray copy
    Have been a DVDFab customer for many years but am now thoroughly confused!
    At present using Trial version but when I go to buy I tick copy but when I go to checkout I am also charged for a "passkey" which doubles the price and makes it very expensive. Am I doing something wrong??
    Appreciate your help
    phil2
    Hi phil2
    Working fine for me.
    Are you also using the 25% off coupon code, Save 25% now buying any DVDFab product. Coupon Code:FAB-WPL-OFF, Valid to Feb 3, 2013
    There should also be an option to remove Passkey before you check out.
    CBR929
      Hi CBR929,
      Thanks for reply and heads up about discount.Blu-ray purchased today
      Regards Phil
