Temporary fix for the Cinavia problem
    Media Players Temporary fix for the Cinavia problem
    A temporary fix for the Cinavia problem I discovered with my DVD player is that when the Cinavia comes up (usually after about 20 minutes of play time) … do a pause and stop. Power down and turn off the player! Turn the power back on and continue playing your movie at the point you left off for another 20 minutes until the Cinavia comes up again and repeat until you’re finished! I tried this last night and after 5 power downs (short annoyances) – I watched the entire movie.
    geh
    are you playing the movie by disc or media player??
    as far as i know VCR/DVD combo players are not infected with cinavia.
    and media players are immune to cinavia.
      (Correction) I'm playing the movie by disk in my DVD player which has the cinavia.
      geh
        is the dvd player connected to the internet??
          Yes it is.
            just put your movies on a media player of some kind
            and never have to worry about cinavia again.
              I do but this is for anyone else that who does not have other player(s) to play it on !
                just buy an older dvd player, one that doesn't have internet connection.
                the same can be said for some bluray players.
                  october262 - If you are having a cinavia problem with your dvd player ... you can just following my instructions in post 1 to temporary help with it !!
                    BUY A Panasonic DVD-S700 1 Disc(s) DVD Player - 1080p ITS CINAVIA FREE INTERNET FREE AND IS CHEAP $45-61 AND IS AVAILABLE CURRENTLY.
                      geh,
                      Which make and model of DVD player do you have?
                      I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
                      I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
                        Originally posted by SeeMoreDigital View Post
                        geh,
                        I have a Sony Blu-Ray Disc / DVD Player BDP - BX510 that has the Cinavia problem.
                        geh
                          Out of interest...
                          Have you tried backing-up your Cinavia disc's to .mkv contained files, loading them onto an external HDD and playing them via your Sony's USB port?
                          Cheers
                            Out of interest...
                            Cheers
                            Thanks SeeMoreDigital,
                            That would be something I would like to try to do but I don't know how to do that (backing-up ... to .mkv contained files ... and then transfer it to USB) ?? Any help on doing this would be very appreciated.
                              blue-ray to MKV converter tutorial - http://www.dvdfab.cn/tutorial/Convert-Blu-ray-to-MKV
