.avi to dvd? help!
    .avi to dvd? help!
    Hello, I have recorded my sons little league baseball games for the season and they are all saved on my computer as .Avi files, how can I use DVDFab 7 to put all 19 clips onto 2 dvd'S? The total file size all the clips are 5.13 gigs.. However I will be doing half on one disc and half on the other.
    When I use DVDFab 7, I can convert the files to another file type, but I did not find how to burn them onto a dvd. Please help !!
    DVDFab will not turn AVI's into a DVD structure, You will need to find another program to do this.
      I deleted the 2 previous posts also studsta57 if you want them on DVD just type what you need into google and you will get it. This DVDFab forum and is meant to support DVDFab products and is not a place to come looking for other programs to do something else that DVDfab is not able to do at this time.
