DVDFab Forum - Missing strings
Missing strings
  • Missing strings
    DVD to Mobile -> Select any option and then any profile -> Edit:
    Now look at description, e. g: The profile is used to create mp4(h264 + aac) file, which can be played in iPhone.
    All those descriptions are missing from language file, so please add them.
    人生は贈り物であり、完全な喜びを経験する必要があります
  • #2
    Also string for tooltip of iPad on the left side is missing.
    String "DVD image file(*.ini,*.iso,*.img,*.nrg)" is also missing. But please set space before bracket start and after each comma). And btw that string gets also displayed for Blu-ray.
    • #3
      If burn of BD is unsuccessful, it tells "Failed to burn DVD" which is wrong.
      So add string "Failed to burn DVD" and implement the read of that string in program.
      "Show registered Options only" is also missing (settings -> Customize UI)
      Also please add strings "Please choose BD image file" (visible atm with DVD at Clone mode BD at Target).
      • #4
        "Enable full scan (slow but accurate)" is missing.
        • #5
          "Show registered Options only" and "Enable full scan (slow but accurate)" got added in 7.0.7.6 Beta.
          • #6
            Tooltip of Audio profile is missing: "Extract audio from video file"
            • #7
              "You need set output size to BD50 or BD25.\n\nDo you want to make the changes?" is visible when you select BD5 in Main Movie and then check Cinavia checkbox.
              Then press on Start in DVDFab ignoring above msg you will get:
              "You need set burning engine to VSO or ImgBurn, set output size to BD50 or BD25, and set output type to Blu-ray writer which supports binding nonce generation.\n\nDo you want to make the changes?"
