DVDFab need to close when selecting another copy
    Software DVDFab need to close when selecting another copy
    After I burn a disk BR/to DVD Successfully and select another copy DVDFab comes back and says it needs to close and I have to start all over again.
    Thank You Very Much
    So what module are you using DVDFab Blu-ray copy to a BD5 or BD9 or are you using the DVDFab Blu-ray to DVD Converter
      To BD5
      Could CyberLink Power DVD Auto start cause it?
        Hi, VIPERGTS,
        Please turn it off to see the result.
        If some other programs are trying to access your optical drive or already have control of it before DVDFab attempting to write. It may result in the problem.
        When you copy and burn movie DVDs with DVDFab, please disable all the other background tasks in your windows task manager.
        Sincerely Yours
        Malcolm Wang
          like malcom mentioned turn off your Autoplay as this will always happen if it enabled
