error 105??
    Other error 105??
    I have been getting this error lately when trying to back up my dvds.
    its getting frustrating!!!!
    any help would help! thanks in advance
    starbright3d
    Need more info
    Please post you logs the default location is:
    Please just attach your most recent, Internal and Burn log(s) and post right here.
    CBR929
      If this is an error during burning, then your files are too large for an SL disc; probably just an incorrect setting.
      Without details however, it's all just guesswork.
      Please do as CBR929 suggested.
        19:44:23: The "DVD Copy" option is expired. You are going to use "HD Decrypter".
        19:44:23: Analyzing of DVD started
        19:44:23: Analyzing of DVD completed successfully
        19:44:23: Copy process started
        20:11:15: Copy process completed successfully
        20:18:27: Burn DVD folder (C:\Users\Dawn\Documents\DVDFab\Temp\FullDisc\TINK ER_BELL\) started
        20:25:50: Task_2 failed! Error=105
          The free HD Decrypter does not compress and it does not burn.
          It will rip to your hard drive only/.
            I don't see how. Cuz I've been using this for years and it has always worked for me but recently.
              The free version has never compressed .
              It has never had the ability to burn to a disc.
              It will rip in full disc mode or main movie mode to a hard drive only.
              I have no idea what you have been using for years to compress and burn but it was not the free HD Decrypter
                Hi starbright3d,
                Please tell us if you are our registered user.
                If yes, please offer us your registered email or order number when purchasing. And then we will check in our database and help you to solve your issue.
                Please send your email to anny@dvdfab.com.
                Best regards,
                Anny
                DVDFab Support Team
