program usage
    Other program usage
    It is possible to use the program on a desktop and laptop computer without paying for 2 programs?
    I believe yes, providing they aren't running at the same time...Otherwise you will be blacklisted...
      Hi TexLin
      The answer is "Yes", you can install it and use it on your desktop and Laptop but,
      DO NOT use them at the same time or you take the chance of your Key being Blacklisted and you will not be able to use it at all.
      CBR929
