error 400
    error 400
    xpsp2. Dvdfab v8.0.3.2 and v7.0.8.2.
    Have a Showtime series disk that when using Full Disc or Customize, session halts right after starting with an error 400. Main Movie will copy only title 1 (writing to hdd.) Same with two different drives. PathPlayer enabled or disabled does not make a difference. The only other reference to this in the forums (same series even) seemed to point to embedded software.
    Any suggestions for work-arounds?
    Please update to the latest beta, 8.0.5.3 and post your logfiles as directed in the Help Us Help You sticky. We'll be able to help you further then.
    SPECS
      If you will excuse me, I don't wish to install a beta release at this time. I see that there is a newer version and will install it. But below are the logs for my current version.
      DVDFab 8.0.3.2 (2010/12/03 23:43:43)
      0m 00.40s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
      0m 08.87s: detected dvd
      0m 08.89s: drive E
      0m 08.89s: dvd type 1
      0m 08.89s: volume label LWORD
      0m 08.96s: detected dvd
      0m 09.00s: drive E
      0m 09.00s: dvd type 1
      0m 09.00s: volume label LWORD
      0m 16.42s: got copyright 1 c0
      0m 16.67s: got udf/iso
      0m 17.50s: got discinfo
      0m 17.50s: pathplayer disabled 0
      0m 19.20s: got dvdinfo
      0m 53.67s: dvd transcoder 25 10
      23:44:37: Analyzing of DVD started
      23:44:37: Analyzing of DVD completed successfully
      23:44:37: Copy process started
      23:44:37: Task_1 failed! Error=400()
      2010-12-03 23:44:44 ---- ******************** Log session stop 03-Dec 23:44:44.546 PID 1068********************
      2010-12-03 23:43:46 Info Current Drive selected : 0:0:0 - ATAPI iHAP422 9 WL1G [D] (Ide)
      2010-12-03 23:43:46 Info Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
      2010-12-03 23:43:46 Info System default language : English (United States)
      2010-12-03 23:43:46 Info User default language : English (United States)
      2010-12-03 23:43:46 Info DLL Version : 4.0.11.473
      2010-12-03 23:43:46 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
      2010-12-03 23:43:46 Info Version : 8, 0, 3, 2
      2010-12-03 23:43:46 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
      2010-12-03 23:43:46 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 2)
      2010-12-03 23:43:46 ---- ******************** Log session start 03-Dec 23:43:46.406 PID 1068********************
        install the latest Official release then as the version you have is an old version that was released October 30, 2010
        Much better to keep DVDFab updated even if it a Beta as a Beta may fix an issue you have but the Error 400 you are getting is a transcoder error.
        set Pathplayer to always enabled and try changing the A/V codec setting to Software for all options available to you. To do this you need to go into common settings the green dot with check amrk top right of dvdfab
          Hi gobo
          If I can also add to AGJ excellent advise you really should up date your OS from SP2 to SP3 from Microsoft
          CBR929
            as requested.
            DVDFab 8.0.5.5 (2010/12/04 20:44:54)
            0m 00.43s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
            0m 27.40s: detected dvd
            0m 27.45s: drive D
            0m 27.45s: dvd type 1
            0m 27.45s: volume label LWORD
            0m 31.81s: got copyright 1 c0
            0m 32.43s: got udf/iso
            0m 33.56s: got discinfo
            0m 33.56s: pathplayer disabled 0
            0m 34.31s: got dvdinfo
            2m 21.31s: dvd transcoder 25 10
            20:47:15: Analyzing of DVD started
            20:47:15: Analyzing of DVD completed successfully
            20:47:15: Copy process started
            20:47:15: Task_1 failed! Error=400()
            2010-12-04 20:47:24 ---- ******************** Log session stop 04-Dec 20:47:24.000 PID 1992********************
            2010-12-04 20:44:56 Info Current Drive selected : 0:0:0 - ATAPI iHAP422 9 WL1G [D] (Ide)
            2010-12-04 20:44:56 Info Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
            2010-12-04 20:44:56 Info System default language : English (United States)
            2010-12-04 20:44:56 Info User default language : English (United States)
            2010-12-04 20:44:56 Info DLL Version : 4.0.13.476
            2010-12-04 20:44:56 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
            2010-12-04 20:44:56 Info Version : 8, 0, 5, 5
            2010-12-04 20:44:56 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
            2010-12-04 20:44:56 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 2)
            2010-12-04 20:44:56 ---- ******************** Log session start 04-Dec 20:44:56.468 PID 1992********************
              Higobo
              Your logs still say path player is not enabled Open Fab Click the Green top right > Protection > Path Player click Always Enabled click OK restart Fab and try again.
              CBR929
                With PathPlayer enabled, it writes about 126kb to the disk and only one log file.
                DVDFab 8.0.5.5 (2010/12/04 20:55:22)
                0m 20.98s: detected dvd
                0m 21.03s: drive D
                0m 21.03s: dvd type 1
                0m 21.03s: volume label LWORD
                0m 26.67s: got copyright 1 c0
                0m 27.29s: got udf/iso
                0m 28.40s: got discinfo
                0m 28.42s: pathplayer enabled
                0m 28.50s: got dvdinfo
                  That last did not seem right with only one log file, tried again after a reboot and got two. What I noticed second time around is with Full Disc selected, under Quality it says 0MB -> 0MB. Here are the correct files.
                  DVDFab 8.0.5.5 (2010/12/04 21:59:08)
                  0m 17.60s: detected dvd
                  0m 17.65s: drive D
                  0m 17.65s: dvd type 1
                  0m 17.65s: volume label LWORD
                  0m 20.28s: got copyright 1 c0
                  0m 20.90s: got udf/iso
                  0m 22.03s: got discinfo
                  0m 22.04s: pathplayer enabled
                  0m 22.10s: got dvdinfo
                  DVDFab 8.0.5.5 (2010/12/04 22:01:57)
                  0m 00.45s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
                  2010-12-04 22:02:12 ---- ******************** Log session stop 04-Dec 22:02:12.140 PID 516********************
                  2010-12-04 22:01:59 Info Current Drive selected : 0:0:0 - ATAPI iHAP422 9 WL1G [D] (Ide)
                  2010-12-04 22:01:59 Info Using SPTI interface
                  2010-12-04 22:01:59 Info System default language : English (United States)
                  2010-12-04 22:01:59 Info User default language : English (United States)
                  2010-12-04 22:01:59 Info DLL Version : 4.0.13.476
                  2010-12-04 22:01:59 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
                  2010-12-04 22:01:59 Info Version : 8, 0, 5, 5
                  2010-12-04 22:01:59 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
                  2010-12-04 22:01:59 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 2)
                  2010-12-04 22:01:59 ---- ******************** Log session start 04-Dec 22:01:59.046 PID 516********************
                  2010-12-04 22:00:08 ---- ******************** Log session stop 04-Dec 22:00:08.421 PID 896********************
                  2010-12-04 21:59:10 Info Current Drive selected : 0:0:0 - ATAPI iHAP422 9 WL1G [D] (Ide)
                  2010-12-04 21:59:10 Info Using SPTI interface
                  2010-12-04 21:59:10 Info System default language : English (United States)
                  2010-12-04 21:59:10 Info User default language : English (United States)
                  2010-12-04 21:59:10 Info DLL Version : 4.0.13.476
                  2010-12-04 21:59:10 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
                  2010-12-04 21:59:10 Info Version : 8, 0, 5, 5
                  2010-12-04 21:59:10 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
                  2010-12-04 21:59:10 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 2)
                  2010-12-04 21:59:10 ---- ******************** Log session start 04-Dec 21:59:10.625 PID 896********************
                    Hi gobo,
                    For your problems, could you please copy the other DVDs to see if this is a universal problem (task1_error400), or just for this movie ?LWORD??
                    Please upgrade to the latest version of DVDFab 8.0.5.6 at .
                    Sincerely,
                    Sunny
                    ________
                    WITCHCRAFT ADVICE
                      Originally posted by sunny View Post
                      Hi gobo,
                      For your problems, could you please copy the other DVDs to see if this is a universal problem (task1_error400), or just for this movie “LWORD”?
                      Sincerely,
                      Sunny
                      The error400 is just for this disc. I made a clone iso image of this disc to hdd, but DvdFab does not seem to be able to read it.
                      19:17:25: Analyzing of DVD started
                      19:17:25: Analyzing of DVD completed successfully
                      19:17:25: Copy process started
                      19:17:25: Task_1 failed! Error=400()
                      DVDFab 8.0.5.6 (2010/12/06 19:17:01)
                      0m 03.45s: detected dvd
                      0m 03.48s: drive E
                      0m 03.48s: dvd type 1
                      0m 03.48s: volume label LWORD
                      0m 05.93s: got copyright 1 c0
                      0m 06.56s: got udf/iso
                      0m 07.17s: got discinfo
                      0m 07.18s: pathplayer disabled 0
                      0m 08.15s: got dvdinfo
                      0m 24.39s: dvd transcoder 25 10
                      DVDFab 8.0.5.6 (2010/12/06 19:20:21)
                      0m 54.11s: detected dvd
                      0m 54.11s: iso C:\Documents and Settings\gobo\My Documents\DVDFab\ISO\LWORD\LWORD_S2D4.iso
                      0m 54.11s: dvd type 1
                      0m 54.11s: volume label LWORD
                      0m 55.92s: got copyright 0 0
                      0m 56.70s: got udf/iso
                      1m 25.12s: detected dvd
                      1m 25.12s: iso C:\Documents and Settings\gobo\My Documents\DVDFab\ISO\LWORD\LWORD_S2D4.iso
                      1m 25.12s: dvd type 1
                      1m 25.12s: volume label LWORD
                      1m 27.82s: got copyright 0 0
                      1m 27.82s: got udf/iso
                      2m 15.76s: detected dvd
                      2m 15.76s: iso C:\Documents and Settings\gobo\My Documents\DVDFab\ISO\LWORD\LWORD_S2D4.iso
                      2m 15.76s: dvd type 1
                      2m 15.76s: volume label LWORD
                      2m 17.42s: got copyright 0 0
                      2m 17.42s: got udf/iso
                      2010-12-06 19:17:36 ---- ******************** Log session stop 06-Dec 19:17:36.578 PID 1464********************
                      2010-12-06 19:17:03 Info Current Drive selected : 0:0:0 - ATAPI iHAP422 9 WL1G [D] (Ide)
                      2010-12-06 19:17:03 Info Using SPTI interface
                      2010-12-06 19:17:03 Info System default language : English (United States)
                      2010-12-06 19:17:03 Info User default language : English (United States)
                      2010-12-06 19:17:03 Info DLL Version : 4.0.13.476
                      2010-12-06 19:17:03 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
                      2010-12-06 19:17:03 Info Version : 8, 0, 5, 6
                      2010-12-06 19:17:03 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
                      2010-12-06 19:17:03 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 2)
                      2010-12-06 19:17:03 ---- ******************** Log session start 06-Dec 19:17:03.562 PID 1464********************
                      When opening the iso image, it does not display any titles. Only this entry in the logs.
                      DVDFab 8.0.5.6 (2010/12/06 19:26:41)
                      0m 16.14s: detected dvd
                      0m 16.14s: iso C:\Documents and Settings\gobo\My Documents\DVDFab\ISO\LWORD\LWORD_S2D4.iso
                      0m 16.14s: dvd type 1
                      0m 16.14s: volume label LWORD
                      0m 17.76s: got copyright 0 0
                      0m 17.76s: got udf/iso
