Usage Questions
    Usage Questions
    Hello,
    I prefer to uncheck the subpicture option when I rip a DVD.
    Is it possible to make this the default setting each time I start DVDFab and use the DVD ripper?
    In the Common Settings>DVD/BLU ripper>Output window I have the output file name pattern for "Volume" set to the <volume> pattern.
    This sets my output filename to just the name of the volume under the Conversion window in the ripper.
    Is it possible to have the "Title" setting in the "Conversion Window" to do the same?
    Thank you,
    Dana
    Dana
    Open Fab click the Click the Green at top right corner of the DVDFab screen, and open Common Settings > General > DVD/Blu-Ray > Streams > Subpicture > Do not preselect any subpicture tract click OK restart Fab.
    CBR929
      Thank you.
        Your welcome
        CBR929
