I paid and downloaded dvdfab platinum a few years ago to my computer where I used to live with my folks. Now I have my own house and a much better computer. I still used dvd fab at my old residence up until my modem went on the fritz. I can't download any updates to the program. My question is this: How can I move the program to my computer at my house.
Migrating dvdfab to another computer
Guest
Download to a Flash drive / thumb drive/memory stick.
If you can post here then you can also download the software.
Guest
Originally posted by clyderbw View PostCan you elaborate a little?
If you are on the internet and able to make a post here then you are also able to download the software.
Not sure what you meant in your post that you were unable to download updates.
Download to a thumb drive --- take it to your PC--- download to your PC-- install the software and activate using your original key.
Originally posted by clyderbw View PostThat simple? Isn't there security features to prevent that?
(Tip: If you plan on selling the old computer make sure you remove all traces of Fab and remove the registry setting that has your personal key info or just re-format the hdd and reinstall windows)
Originally posted by W&B View PostYou can only run your registered DVDFab on 1 computer at a time or your key will be blacklisted. Other than that knock yourself out.
Originally posted by W&B View PostSo you want to keep the old version and install it to the new computer? Go to oldapps.com and D/L the old version there if that's the case.
Hi clyderbw
Here are instructions from mona:
1. Please register in DVDFab "Members" with your registered email address used for your purchase > go to your email to activate your account > back to "Members" to download key. (If you still have trouble activating your account in DVDFab user center, please write to mona@dvdfab.com and provide us your registered email address or order number, then we will help you get through this.)
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by clyderbw View PostAll I want to do is get the newest version of the program on my new computer. However possible. I don't need it on the old computer since I wasn't able to get updates. Hasn't anyone scrapped an old computer and migrated dvdfab to a new one?
Guest
This is being made much more difficult then it needs to be.
The instructions in post #2 was all you needed to do.
I'mconfused
