8.0.5.6 bluray Disk customize Issue
    I recently picked up a history channel bluray DVD called the universe and it has five separate movie titles on it. There doesn't seem to be an option that will let me select all five titles it will only let me choose one at a time. I am using 25 GB dvds burn the project on and I don't want to use the full disk option, or the clone option. I am thinking that the only way to do this without too much compression is to make five separate dvds which I don't want to do. Is it possible to put only all five titles onto one DVD?
    Thanks for looking at thanks for your help.
    Hi lee,
    Not yet.
    For the present you're stuck with Full Disc or Main Movie just as you described.
    BD Customize is in the works and should available with an updated version very soon.
    Sorry, I don't have a specific date/version yet.
