Since loading the latest version of DVDFab on both my PC and Laptop, getting erroe code 700, then a pop up message: Operation Failed.
Error Code 700
You will have to explain in more detail what you're trying to do, step by step. Also, what movie are you trying? What module are you using? What are your settings? Why is the sky blue? Stuff like that. Also, have a read through the Help Us Help You sticky and follow the directions there. It will tell you how to post the DVDFab logfiles as well. Good luck.SPECS
