DVDFab: Menus are displayed in "gibberish?"
    I tried downloading the demo/trial of DVDFab today but encountered a problem, the set up went fine, with everything displayed in English, but once I run the program, all words are displayed in computer "gibberish." Is there any way to fix this so I can try the program?
    Here's an image of the gibberish text:
    Go to your menu page and try to find languages. See if somehow that got changed.
    Into abyss
    You don't exist
    Cannot resist
    The Judas kiss
    Judas lives recite this vow
    I've become your new god now
      How do I get to the menu page? I can't read any of the buttons.
        Should be a green check mark button on the top right corner. After that, I'm at work right now and not near my computer to tell you where the language portion of that page is. Maybe someone can pull it up and give you a screen shot or a walk-through where the laguage portion is. Since it's in another language, it can be hard to find since you can't read it. (obviously)
        Into abyss
        You don't exist
        Cannot resist
        The Judas kiss
          Yes! I went to the language section and discovered that the language was set under Chinese Traditional (my computer's default language.) Changing it to English fixed the problem. Thanks!
          On a side note however, I recognize that the gibberish isn't Chinese; I think it's a mix of computer symbols. DVD fab must have trouble displaying the Chinese.
            Glad I was able to help.
            Into abyss
            You don't exist
            Cannot resist
            The Judas kiss
              Strange as the developer of DVDFab is Chinese I believe so DVDFab should have no problem with that language
                Non-English OS
                There are non-English versions of the Windows OS.
                  I know that and was not refering to the OS
