I'm new to dvdfab.
    Originally posted by jdog091376 View Post
    Just thought I'd let you know case over and got my money back simple fast easy.
    Thanks bro using the beta from the real site and it works fine once I learn how to use it I will be buying the lifetime br to br those scammers hope they get what's coming to them. Is it better just to burn to a 50gb disk? I burned the movie ulgy truth for my wife and it ended up with a voice over can't seem to figure out the audio. So the only thing I can say if you burn with a 50gb it takes less time to download because it does not have to compress and you don't have to worry about the audio just keep the HD audio is this correct or no.
      Hi jdog091376,
      For your problem, please post your log files.
      The default location is:
      Thanks in advance.
      Best regards,
      Anny
        If you do not want the voice over then you need to keep the DTS HD when you do Main Movie. If you not want the DTS HD then select Remove HD Audio and you should not have the voice over problem.
