blu-ray/dvd drive
    Optical Drives blu-ray/dvd drive
    hi all, just recieved new external blu-ray burner LG BE12LU30, connected no problem it shows up in device manager as using Scsi format (dont know if thats better than IDE/ATAPI) but doesn't say if its in PIO or DMA mode just says this device is working correctly, so opened up imgburn and it shows up in there as RAID (dont know what that means either!) i burned a dvd from my hard drive with imgburn which took about 25mins then let it verify the disc which took another 25mins, do you really have to verify the disc ? do these times sound normal for dvds. im running windows 7 home premium 32/64 bit system on an acer 7811 pc. heres the logs. I 12:38:10 ImgBurn Version 2.5.5.0 started!
    I 12:38:10 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7600)
    I 12:38:10 Total Physical Memory: 8,346,688 KB - Available: 6,859,880 KB
    I 12:38:10 Initialising SPTI...
    I 12:38:10 Searching for SCSI / ATAPI devices...
    I 12:38:10 -> Drive 1 - Info: HL-DT-ST DVDRAM GH41N MN01 (E (ATAPI)
    I 12:38:10 -> Drive 2 - Info: HL-DT-ST BD-RE BE12LU30 4261 (F (RAID)
    I 12:38:10 Found 1 DVD±RW/RAM and 1 BD-RE!
    I 12:41:00 Operation Started!
    I 12:41:00 Building Image Tree...
    I 12:41:00 Checking Directory Depth...
    I 12:41:00 Calculating Totals...
    I 12:41:00 Preparing Image...
    I 12:41:18 Using Layer Break LBA: 2060437 -> 2060448 (VTS_05, PGC: 1, Chapter: 10, Cell: 10, Vob/Cell ID: 1/10, Time: 01:16:28, SPLIP: Yes)
    I 12:41:19 Checking Path Length...
    I 12:41:19 Contents: 33 Files, 2 Folders
    I 12:41:19 Content Type: DVD Video
    I 12:41:19 Data Type: MODE1/2048
    I 12:41:19 File System(s): ISO9660, UDF (1.02)
    I 12:41:19 Volume Label: [Not Configured]
    I 12:41:19 IFO/BUP 32K Padding: Enabled
    I 12:41:19 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
    I 12:41:19 TV System: PAL
    I 12:41:19 Size: 8,044,347,392 bytes
    I 12:41:19 Sectors: 3,927,904
    I 12:41:19 Image Size: 8,045,068,288 bytes
    I 12:41:19 Image Sectors: 3,928,256
    I 12:41:19 Operation Successfully Completed! - Duration: 00:00:18
    I 12:43:09 Operation Started!
    I 12:43:09 Building Image Tree...
    I 12:43:20 Checking Directory Depth...
    I 12:43:20 Calculating Totals...
    I 12:43:20 Preparing Image...
    I 12:43:30 Using Layer Break LBA: 2060437 -> 2060448 (VTS_05, PGC: 1, Chapter: 10, Cell: 10, Vob/Cell ID: 1/10, Time: 01:16:28, SPLIP: Yes -> No)
    I 12:43:30 Checking Path Length...
    I 12:43:30 Contents: 33 Files, 2 Folders
    I 12:43:30 Content Type: DVD Video
    I 12:43:30 Data Type: MODE1/2048
    I 12:43:30 File System(s): ISO9660, UDF (1.02)
    I 12:43:30 Volume Label: EDGE_OF_DARKNESS_UK_RETAIL
    I 12:43:30 IFO/BUP 32K Padding: Enabled
    I 12:43:30 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
    I 12:43:30 TV System: PAL
    I 12:43:30 Size: 8,044,347,392 bytes
    I 12:43:30 Sectors: 3,927,904
    I 12:43:30 Image Size: 8,045,035,520 bytes
    I 12:43:30 Image Sectors: 3,928,240
    I 12:43:38 Operation Successfully Completed! - Duration: 00:00:29
    I 12:43:38 Operation Started!
    I 12:43:38 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 12:43:38 Source File Sectors: 3,928,240 (MODE1/2048)
    I 12:43:38 Source File Size: 8,045,035,520 bytes
    I 12:43:38 Source File Volume Identifier: EDGE_OF_DARKNESS_UK_RETAIL
    I 12:43:38 Source File Volume Set Identifier: 3E306564003BF0AA
    I 12:43:38 Source File Application Identifier: IMGBURN V2.5.5.0 - THE ULTIMATE IMAGE BURNER!
    I 12:43:38 Source File Implementation Identifier: ImgBurn
    I 12:43:38 Source File File System(s): ISO9660, UDF (1.02)
    I 12:43:38 Destination Device: [0:0:0] HL-DT-ST BD-RE BE12LU30 4261 (F (RAID)
    I 12:43:38 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x, 8x)
    I 12:43:38 Destination Media Sectors: 4,173,824
    I 12:43:38 Write Mode: DVD
    I 12:43:38 Write Type: DAO
    I 12:43:38 Write Speed: 4x
    I 12:43:38 Link Size: Auto
    I 12:43:38 Lock Volume: Yes
    I 12:43:38 Test Mode: No
    I 12:43:38 OPC: No
    I 12:43:38 BURN-Proof: Enabled
    I 12:43:38 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
    I 12:43:38 Book Type Setting: DVD-ROM
    I 12:43:38 Optimal L0 Data Zone Capacity: 2,060,448
    I 12:43:38 Optimal L0 Data Zone Method: IFO Cell Boundary
    I 12:44:10 Set L0 Data Zone Capacity Succeeded!
    I 12:44:10 Filling Buffer... (40 MB)
    I 12:44:11 Writing LeadIn...
    I 12:44:12 Writing Session 1 of 1... (1 Track, LBA: 0 - 3928239)
    I 12:44:12 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3928239)
    I 12:44:12 Writing Layer 0... (LBA: 0 - 2060447)
    I 12:57:06 Writing Layer 1... (LBA: 2060448 - 3928239)
    I 13:08:56 Synchronising Cache...
    I 13:08:57 Closing Track...
    I 13:09:03 Finalising Disc...
    I 13:10:51 Exporting Graph Data...
    I 13:10:51 Graph Data File: C:\Users\gordon\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BE12LU30_4261_16-JANUARY-2011_12-43_MKM-003-00_4x.ibg
    I 13:10:51 Export Successfully Completed!
    I 13:10:51 Operation Successfully Completed! - Duration: 00:27:12
    I 13:10:51 Average Write Rate: 5,297 KB/s (3.8x) - Maximum Write Rate: 5,589 KB/s (4.0x)
    I 13:10:51 Cycling Tray before Verify...
    W 13:11:00 Waiting for device to become ready...
    I 13:11:12 Device Ready!
    I 13:11:13 Operation Started!
    I 13:11:13 Source Device: [0:0:0] HL-DT-ST BD-RE BE12LU30 4261 (F (RAID)
    I 13:11:13 Source Media Type: DVD+R DL (Book Type: DVD-ROM) (Disc ID: MKM-003-00) (Speeds: 4x, 8x)
    I 13:11:13 Image File: -==/\/[BUILD IMAGE]\/\==-
    I 13:11:13 Image File Sectors: 3,928,240 (MODE1/2048)
    I 13:11:13 Image File Size: 8,045,035,520 bytes
    I 13:11:13 Image File Volume Identifier: EDGE_OF_DARKNESS_UK_RETAIL
    I 13:11:13 Image File Volume Set Identifier: 3E306564003BF0AA
    I 13:11:13 Image File Application Identifier: IMGBURN V2.5.5.0 - THE ULTIMATE IMAGE BURNER!
    I 13:11:13 Image File Implementation Identifier: ImgBurn
    I 13:11:13 Image File File System(s): ISO9660, UDF (1.02)
    I 13:11:13 Read Speed (Data/Audio): MAX / MAX
    I 13:11:13 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3928239)
    I 13:11:13 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3928239)
    I 13:11:13 Verifying Layer 0... (LBA: 0 - 2060447)
    I 13:32:19 Verifying Layer 1... (LBA: 2060448 - 3928239)
    I 13:39:56 Exporting Graph Data...
    I 13:39:56 Graph Data File: C:\Users\gordon\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BE12LU30_4261_16-JANUARY-2011_12-43_MKM-003-00_4x.ibg
    I 13:39:56 Export Successfully Completed!
    I 13:39:56 Operation Successfully Completed! - Duration: 00:28:42
    I 13:39:56 Average Verify Rate: 4,562 KB/s (3.3x) - Maximum Verify Rate: 11,332 KB/s (8.2x)
    I 13:48:35 Close Request Acknowledged
    I 13:48:35 Closing Down...
    I 13:48:36 Shutting down SPTI...
    I 13:48:36 ImgBurn closed!
    Hi flashgordon,
    Generally speaking, if the burning process finished successfully, you will get a good burned disc, and you have no need to verify it.
    Please don't verify the disc, and play the burned disc directly in your standalone player to see the result.
    Regards,
    mona
