Changing Region On DVDs
    Hi
    I specifically got DVD Fab so i can change the region on my wedding films so i can send them to family and friends but i can t manage to do this can someone please help me
    If the DVD your wedding films are in are DVD compliant format then DVDFab can do that all you need to do is make a copy of the original DVD that has the wedding film on using DVDFab and the copy will be region free. But the DVD probably already region free as my Wedding DVD is region free. Your DVD might be in PAL format and may need to be in NTSC Format which DVDFab not able to do. What region was the wedding film made originally and as well post internal log for DVDFab.
      im very sorry im not a big tech wizz but i know it was made in Weston Wurope region(UK)
      i need to change it so it works in the usa/canada region
      is this possible, if i copy the DVD and than burn it can i change the region,
      when coping the DVD it ask me what Region the dvd is in but it does not ask me what region i wanna burn it to
      thanks for the reply
        You are confusing the terminology.
        As stated in Post #2
        DVDFab makes your copy region free.
        DVDFab can not change the format of the disk.
        The UK is PAL format.
        The U.S. and Canada are NTSC format.
        There is other software that can change the format for you.. Use Google to find it.
          When being asked for region all you do is select the region the DVD is and DVDFab will make the copy region free but will not convert PAL to NTSC like already mentioned need other program for that
