Upgrading my computer
    Other Hardware Upgrading my computer
    hi all
    Just some general enquiries. I've got DVD blue Ray 2 DVD copier. It takes about 5 hours to do, I'm going to upgrade my computer to a dual core processor and 4 gig of ram . I was just wondering if this will cut the time down to copy a blue Ray 2 DVD, I know it may be a silly question but I do not want to pay out on a new motherboard and processor if this is not going to really speed up the process. At the moment I'm running a single processor and 1 gig of ram. Thank you in advance for all your answers.
    :) never look down on anyone unless you're looking down at them to help them up:)
    Well, yes it will be faster, but by how much? how much did it cost you?
    and did you get the biggest bang for your buck?
    It's a balancing act as to what you want and what you can afford.
    You need a robust cpu. Since you're biting the bullet and buying a new motherboard, go with the most robust cpu you can afford.
    Personally, if I were going to do it (and I did), go with a core i7 /Quad and you can keep it under $300.
    You also need a decent NVIDIA CUDA enabled card and a decent psu
    Give us an idea of your budget.
    Will you be doing the build?
    There was a recent thread like this one. For starters, you might want to look it over:
      hi
      Thank you for your reply. At the moment I run on Windows xp pro sp3 . The processor is a Intel Pentium 4 3.6 ghz . With 1gb of RAM and a Intel graphics controller. The new motherboard and processor I'm thinking about buying is a Intel Pentium dual core e5700 3.0ghz and 4gb ddr3 1333 mhz ram. I will be doing the installation myself. My budget is about £150 . One more question I'm only running at the moment on 1 gb of RAM would it increase the speed of what I've got if I increase the RAM to 2 gb . Once again thank you for your time.
        I'd save your $ until you can upgrade to a beefier cpu.
        1 GB RAM isn't a lot these days, but it's adeqaute for XP, the least of your problems, and will not offer a reasonable cost to benefit ratio here.
        After your cpu, you need to dump the onboard video and move up to a decent NVIDIA CUDA enabled card.
        I just don't think the money you're spending is worth the performance you'll realize...JMO
          hi
          Thank You maineman for your honest advice it is much appreciated. I thought if I upgraded my processor and ram it would speed up the complete blue ray 2 DVD a lot quicker, if it's only going to do it a little bit quicker then I might as well save my pennies and wait until I can afford a better setup. Once again thank you for your time and advice
