This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
What is the best blank BD-R disc to use? I'v been using Verbatim 25-g LTH as the 50-g are still to expensive, should I use single or double layer?
Thanks for helping a beginner!
I have been having good luck with the Memorex BD-R's lately. No coasters and if you search around on various sites, you can pretty much get them for like $1.10 per disc. I use single layer discs as much as possibe for the same reason you said above, duals are too expensive. I only use duals for my favorite movies that I want all the special features with it. I compress main movie to fit on one single and that has been working great for me thanks to DVDFab even with 80%+ compression ratios. If money isn't an option you can get duals for around $5.50 per disc, but if your like me and like to keep it cheap, stick with the single layers.
