which dvd burner should I get so that they will play in the dvd player in my car?
    Optical Drives which dvd burner should I get so that they will play in the dvd player in my car?
    I currently have asus 24-b1st and it works well, except the disks won't play in my car's built in dvd player
    I'll bet if you get some DVD+R blanks and booktype them to DVD-ROM they would play in the car.
      I tried that and it doesn't work. I think that my brand of my burner doesn't do that correctly. since I am putting another machine together, I am looking for a recommendation on a brand that does do it.
      Thanks,
      Daryl
        I put a couple Samsung 203B drives in my system and they bitset fine. There are several brands that will.
          Thanks, I will look for that one.
          I have been looking around on the internet and that is not one of the things they usually put in the description.
