Blu Ray Copy and DTS
    I cannot get any DTS format to copy. After a certain amount of time which is usually fairly quickly the program stops running, the cpu utilization is very high and it appears the NT Kernel & system is the high user. This is being run in a Win 7 environment and specs for the computer exceed the mininimum requirements by a lot.
    I am wondering if the upload process is the culprit.
    Any ideas?
    I have an idea,
    Read the Help Us Help You sticky and then post all info mentioned to your next post reply to this thread.
