blue ray
    Optical Drives blue ray
    I have for the first time today started to copy a Blue Ray movie Disk (Inception) and itr went ok untill I tried to copy it to my 2nd drive which is a lightscribe DVD reader/Writer by Liteon. My main drive is a Blue Ray LG Reader/Writer, whenn it was ready to send to the 2nd drive it would not find the 2nd drive with the Blue Ray blank disk in it.
    In short do I need another BD reader/writer for the movie to be copied to. I also tried to copy it from the same drive E to E and that went ok, but about 70% through it said it sould not copy to the disk.
    Thanks for any help.
    Hi TUTUTINO,
    If you want to use two drives to back up your Blu-ray discs, you need to make sure that both drives are Blu-ray drives. And the target drive must be a Blu-ray Writer.
    Please post your log files. Thanks in advance.
    The default location is:
    Anny
