Robin Hood Blu-ray
    Robin Hood Blu-ray
    Hello,
    Thank you for reading my post.
    Some of the newer Blu-ray discs tend to split the m2ts file into many smaller m2ts files, making continuous playback impossible. I have copied many of my Blu-rays to my media server, most older movies, but the newer ones are a problem. The Expendables is another example of a Blu-ray that splits the single m2ts into several m2ts files.
    Is there a way around this problem? All I want DVDFab to do is create a single m2ts file.
    I should mention that I primarily use the Blu-ray Copy, Main Movie, feature when this problem occurs.
    Thank you for your feedback.
    Strat
    You would need to use the M2TS output profile in the Blu-Ray Ripper module.
      Many thanks!
