DVDFab and Cores
    CPU/GPU DVDFab and Cores
    Does anybody know if DVDFab will use all 6 cores of a CPU?
    Not sure 100 percent. But I think it does, try trial and see if it use all six cores.
    If you fail to plan...you plan to fail wouldn't you not agree..Think about it
      I don't have the CPU yet. I'm building a computer mainly to do video compression using DVDFab. I got a 1366 mboard from a friend and bought a gtx470 (448 cuda cores). Rest of the sys I'm using spare parts lying around. i7 970 came down in price so wondering if I should go with 6 core vs 4.
