format for Galaxy Tab
    Dear All,
    Which format shoould I chose to Rip BR & DVD for my Galaxy Tab ?
    Thanks a lot!
    Sewaki
    Of the supported formats h.264 is probably your best bet. But experiment a little.
      I have a NookColor which is an android tablet. It only works with the basic h264 encoder. Most profiles use the advanced encoder. Try the NookColor profile I posted. Experiment with volume. I think 200% is ok.
      As an experiment go to archive.org and try a video in 512Kb MPEG4. It should stream. My NC supports video streaming. I put the movies on my in home webserver (IIS). It works great. Unfortunately, DVDFab does not support putting mp4 in video streaming format. There are several conversion programs that do. Send me a PM.
