Cannot figure out save location
    I am having problems locating the folder that the temporary files are going to, and not sure where to look. Can someone please help??
    If you go to "Settings" (Green tick in RH Top corner) then "General", it will show you where the directories are set.
      Sure, we can look.
      Let's see, could you lean a little to the left, ok now dip your right shoulder down a bit and yup, there we go...
      C:\Documents and Settings\Administrator\My Documents\DVDFab\...
      Sorry, couldn't resist...
      The above is the default location as my good friend GregiBoy described.
      You can change the location to anywhere on your hdd(s) that you wish.
      Simply browse to whatever location (file path) you'd like.
      You also have the option to save or delete the temporary directory (where the files are saved on your hdd).
      There are a number of ways to do this.
      The best method is to check or uncheck:
      Delete temporary files when done
      You'll see this option on the same page as above...
        I did not know you were into yoga....................lol
