Total System Freeze
    Total System Freeze
    I'm new to the forum and have been using DVD Fab almost since its inception - I've attached logfiles for information -Basically, I recently recently returned from overseas and updated my system (Windows 7 Professional) with Service pack 1 etc. Then I updated DVD Fab to V8085 - Now I have a "Total Freeze" problem when using BLu Ray Ripper to PS3 -- Everything starts okay but just freezes my whole system, no keyboard, no mouse - This happens after a random amount of time, but mainly as the rip gets towards the end of the BD - I even tried a rip of a BD movie that I had ripped before without problems and this also freezes - Went back to DVD Fab V 8066 and same thing- Is this a Windows 7 SP1 problem or can anyone please help?
    Additional Info re Total Freeze
    The 'Total Freeze' does not occur when using the DVD ripper to PS3 - everything works normally - Even when the 'freeze happens, (I have to re-boot by removing power...), an MP4 file of the BD has been created but cannot be played at all
      Go into "Common Settings" and set all the A/V codecs to softwre and see if that does it.
        'Total Freeze' Problem Fixed
        Thanks for the suggestion - Changing to 'Software' in the AV Codecs fixed the problem and all is now back to normal
        Again - Grateful thanks
          You bet, glad you are going.
