Bootmgr is missing.
    Bootmgr is missing.
    Hi Everyone.
    I am currently using Win 7 Ult 32bit & everytime I use Dvdfab 8.0.8.5 & reboot the computer, I get the "BootMgr is missing" message.
    Has anybody else got this using this version of Dvdfab? I'm only getting this when I use dvdfab, not any other time.
    Thanks
    Does this happen when you reboot after installing DVDFab?
      Yes it did. I had to use the repair option on the Windows setup disc to fix it. Rebooted plenty of times since then with no issues.
      This time I ended up having to reinstall just to get the computer to boot up again.
        Originally posted by choliscott View Post
        Hi Everyone.
        Thanks
        When you run DVDFab do you by chance hook an external drive to your computer to store the backup? If you do leaving it connected during reboot could cause this message to appear.
        Formerly DVDKingdom
          Sounds as a Windows issue.
            It is a Windows problem and not a really rare one either.
              I have one of those external docks that you slide a sata drive into. However I did have the drive i used for data storage when I did my last win 7 install, which caused the message on the first reboot on initial install of dvd fab, but i didn't when i rebooted the next time i used dvd fab.
              For storing any projects, output files, etc.. No I use an internal drive.
                I should add that i have the dock hooked up thru an e-sata port instead of usb.
