HDD Fat32 vs NTFS
    HDD Fat32 vs NTFS
    SO I noticed that I was getting a write error when moving the source BD data to a share folder on my server. The HDD is using FAT32 and had hoped to use it for BD storage. I then thought, this could be an issue with the BD files being well over 4Gb is size so I moved the share to an NTFS partition for testing...Didn't get the write error. I presume that DF only creates the same file sizes as the source? Is there setting to have DF due files at 4Gb max for BD source files?
    It's now big deal if it doesn't. I'll just need to spend some time and back the data up and then reformat the HDD for NTFS.
    Thanks for your time.
    DVDFab is going to leave the BD structure intact and does not have an option for splitting at a 4G limit.
      Ok, what I figured. Had to ask. Thank you for the info.
