BD Ripper General Queries
    Other BD Ripper General Queries
    I should know better but I have a tendency to play with settings, which I really should'nt do without first noting what the original settings were...... Can anyone confirm that 448 kbs is the correct (or default) setting for the Audio Format AAC bitrate?
    What effect will setting this to a higher bitrate have - Better quality audio because of the higher sample rate?
    Finally --- Does anyone know if there is is likely to be a discernable difference in audio quality between AC3 True 5.1 HD and AC3.2 --- I have a Yamaha/Bose multi channel audio system
    Thanks to all
