Too Dark
    Too Dark
    Hi
    Well i have a little problem
    When i ripp my bluray, the movie are darker and the color haved change a little bit it's not bright anymore
    How can i do?
    I wonder... my experience is actually the exact opposite!! The dark areas in my BD rips are not as black as they should be. They seem muddy and too light. Seems like the contrast of the BD rip is off a little bit.
    I like really dark darks and light lites. And the result of the rip seems to lose some of that and overall is more light than it was before the rip.
      Here we are: i took one example but it happen to all the movies
      477m 14.62s: detected blu-ray
      477m 14.62s: drive E
      477m 14.62s: blu-ray type 1
      477m 14.62s: volume label INTO_THE_WILD
      477m 16.44s: root 8CA9E9B1F43A9152_VOLUME_SET_ID:INTO_THE_WILD:INTO_ THE_WILD:INTO_THE_WILD
      477m 16.72s: aacs 1 bd+ 0
      477m 17.08s: got discinfo
      477m 17.25s: got bdmv
      477m 17.27s: got agid 0
      477m 17.29s: sent host cert chal
      477m 17.30s: got drive cert chal
      477m 17.30s: BEC 0
      477m 17.30s: DRIVE_VENDOR 0x0116
      477m 17.33s: got drive key
      477m 17.33s: got host key signature
      477m 17.33s: verified drive signature
      477m 17.33s: verified host signature
      477m 17.38s: sent host signature and key point
      477m 17.38s: got bus key
      477m 17.38s: got volume id
      477m 17.38s: got volume id mac
      477m 17.38s: volume id is correct
      477m 17.38s: got vid
      477m 17.44s: blu-ray 622F34092D7ADB66F9D0F8A152C50B5B3FC2564A
      477m 18.94s: D 94EA2E1A
      477m 18.94s: got vuk
      477m 19.02s: got unit key 1
      477m 44.59s: got extended bdinfo
      477m 44.59s: opened blu-ray
      478m 05.97s:
      478m 05.97s: create config(5)
      478m 05.97s: convert profile(ipad.1080p.mp4)
      478m 05.97s: blu-ray playlist(2) angle(0) chapter(1->20)
      478m 05.97s: stream(4113,VC-1,1) stream(4353,DTS-HD MA,1)
      478m 05.99s: not set correct fourcc for video(28)
      478m 05.99s: info: set output video frame_rate(24/1)
      478m 06.01s: processing source(00002.m2ts)
      478m 06.01s: try to use gpu acceleration(2) for video decoding
      478m 06.01s: DXVA GPU acceleration for video decoding enabled
      478m 07.08s: h264_encode: encode param profile(1) level(41) bitrate(7464)
      535m 29.76s:
        Hi isanka
        Please Open Fab click the Click the Green at top right corner of the DVDFab screen, and open Common Settings > General >A/V Codec, set Video Decoder to Software and set Video Encoder to Software restart Fab and try again.
        CBR929
          well i tried but it's still the same.
          and i check with my bluray player from the computeur and it's the same problem so i think it come from my internal bluray player.
          It's a LG BH10
          graphic card: Ati radeon HD 5700 Serie
            i founded it
            it was my graphic card,
            i set the color for video
              Glad you found it and got it working
              CBR929
