I have numerous lagacy versions of DVDFab under my programs folder. Can I remove these without risking losing security key information and other profile information?
Legacy Versions
Hi zooman,
Originally posted by zooman View PostI have numerous lagacy versions of DVDFab under my programs folder. Can I remove these without risking losing security key information and other profile information?
DVDFab versions like 6.x/7.x/8.x have no affection to each other. You can uninstall those old versions and keep the setup file in case of future need or uninstall and delete them. It is up to you.
About the registration key, you can always login DVDFab user center at to download.
Regards,
mona
