Removing FBI Warning
    I check mark the 'remove FBI warning" when I am making a copy of one of our DVD's - it says you must have navigation path enabled. I read through the help section and can't locate the section on enabling the navigation path.
    Thanks in advance for instructions.
    Randi
    Randi
    What it says is the Navigation Pathplayer must be enabled.
    Open general setting and make sure Pathplayer is checked as Always Enabled.
    Edit to add: Click on the green to get to the General settings.
      Thank you - I've done that before without success. I'll see if it works this time.
      Appreciate your help.
        It works hit and miss .
        It does not always remove the warning for me. Works maybe 95% of the time.
          It's dependent on how the dvd is authored.
          I'm pretty sure if Fab can't "see it" as an individual title, it won't remove it.
            One thing that has always puzzled me is if you convert a movie to a mobile file it doesn't include the fbi warnings, it selects the movie only for encoding, why can't Fab use the same logic to remove those warnings from a dvd copy?
            Anyway try the customize mode and select only the titles and language files you want, Fab usually sees the warnings in that mode as single files and use the preview window.
