Problems burning dvd
    I've tried to burn a movie and a window popped up saying "Failed to burn." I'm not sure if it's my burner or the program. Please help. Here's my log:
    2011-04-14 20:47:53 ---- ******************** Log session stop 14-Apr 20:47:53.856 PID 4968********************
    2011-04-14 20:47:53 Error WRITE FAILED: Can't find write strategy at sector 944
    2011-04-14 20:47:53 Error Write error at 928 (16) - Code 05 21 02 [Illegal request, Invalid address for Write]
    2011-04-14 20:47:53 Info Write started 2202064 sectors to write
    2011-04-14 20:47:53 Info Init success: DVD+R
    2011-04-14 20:47:53 Info Writing speed requested x8.0, effective x8.0
    2011-04-14 20:47:53 Info Available write speed: 16x ,12x ,8x ,6x
    2011-04-14 20:47:53 Info Media ID: MCC-004-00
    2011-04-14 20:47:53 Info Media type: DVD+R
    2011-04-14 20:47:53 Info Scanned files #26, folder #2 - total size 4508682240 b. (4.20 Gb.)
    2011-04-14 20:47:53 Info Inserted media type : DVD+R
    2011-04-14 20:47:53 Info Writable disc DVD+R inserted. Ready to write
    2011-04-14 20:47:53 Info Parsing disc ...
    2011-04-14 20:47:53 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2011-04-14 20:47:53 Info Drive has Serial ATA physical interface
    2011-04-14 20:47:53 Info New Drive selected : 0:0:0 - HP DVD Writer 1170r WH24 [F] (Usb)
    1) It seems that you encountered drive/media compatibility problems.
    You can try different format media like DVD-R/RW if your DVD writer supports. Well-known brands like Taiyo Yuden and Verbatim with the AZO dye on the package will be better. You can consider picking up them.
    2) Also, you burned too fast. Please open "Common Settings" window, click on "write", and slow down write speed to 4.x.
    Anny
      Try using ImgBurn as the burn engine as you are already using Verbatim blank media and burning at 8x speed which is half the rated speed. If you have a internal DVD burner try using that instead as this just might be a USB drive problem.
