[QUOTE=choliscott;83186]Hi Everyone,
Everytime Dvdfab gives me a read error with the ignore, abort, etc prompt. If I hit abort eventually the program goes back to like if you just started the program.
If I put in another disc, the drive light comes on & there is no disc detected. The only way I can get it to work again is to shut down the computer & restart.
Is there something that gets loaded that I can "end task" on if this happens?
Thanks[/QUOTE]
From your description, it sounds like Fab is in conflict with another piece of software for control of your DVD drive.
There's two things you can do...
1.) Give us a complete list of all the software installed on your system - OR -
2.) Download, install and run a piece of software called Imgburn (a freebie on the web - and in the opinion of many here - me included - a better burner than the VSO burner supplied with Fab), go to the tools tab, click on it, then go to the Filter Driver Load Order, click on it, and copy and paste the info this gives you here in your next post.
At that point, we should be able to help you.
DC
:cool:
