Tried downloading and installing software (Win XP) but have been unable to open it, AND more worryingly I cannot uninstall it. Assume it's corrupt, so just tell me how to uninstall it please.
DVD FAB will not open OR uninstall
Guest
Mike there are several threads and many post on this problem.Originally posted by mikeos View PostTried downloading and installing software (Win XP) but have been unable to open it, AND more worryingly I cannot uninstall it. Assume it's corrupt, so just tell me how to uninstall it please.
Search and read to see if there is anything that might help you.
Guest
Using your search words I got 273 hits.Originally posted by mikeos View PostWell I just did exactly that "uninstall dvdfab" and it came up with absoliutely nothing. no link. I just need to know how to uninstall. Does anybody know?
Here is a quote from one of them.
"I was able to remove the new version of DVDFab running freeware REVO I notice when the uninstall starts DVDFab starts up 3 DVDFab.EXE files running as seen by Windows Task Manager so I killed them and it got uninstalled by Revo"
Hi mikeos
Here is one thread that my friend Gruñón is referring to
Hope this helps
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
What I had to do was d/l 8.0.8.9 QT and install it into 8.0.9.2 QT and then used the uninstaller in the program and then it uninstalled with no problemsOriginally posted by mikeos View PostTried downloading and installing software (Win XP) but have been unable to open it, AND more worryingly I cannot uninstall it. Assume it's corrupt, so just tell me how to uninstall it please.Paid Not To Work
US Navy Retired ( 20 Years )
Proudly Served On
USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
6 trips to the Gulf Of Tonkin
