Just a question as support never got back to me. I wanted to make a backup and i used the clone 1-1 option. Is this best option to make backup or everything exactly? Also it asked me what the region code was, i specified A as this is the code. I wanted the output to be ISO so the final output file is an iso to burn to 50gb disc. is it now region free? I want to make sure.
What is "Clone" for
When opening a Bur-ray disc, if you specify the correct disc region like A, the output will be region free for Full Disc, Main Movie and Clone.DVDFab is the all-in-one software package for copying Blu-ray/DVD and converting video file.
http://www.dvdfab.cn
What is "Clone" for
someone mentioned to use
copy FULL MOVIE mode to bd 50 but to backup and existing bluray with EVERYTHING i use clone mode and then output to ISO is this the best way to do it? Im burning to bd50 which option makes exact copy of my full disc? If someone could clear this up would be nice.Last edited by IPopov50; 05-26-2011, 06:27 PM.
@grupar,
"clone" means an exact 1:1 copy of your content. If you want an exact copy of your disc (clone of your disc) - use "Clone" mode. I hope this clear for you....
BTW, I moved your post to a thread of its own.sigpic
Guest
Grupar:
You have asked the same question in 3 different locations on the forum.
Multiple post on the same subject is not the way to make friends on the forum.
Your other posts have been deleted.
Thanks G, I didn't see that. I always assume good of the personsigpic
Guest
Originally posted by IPopov50 View PostThanks G, I didn't see that. I always assume good of the person
It does not pay to repeatedly violate the forum rules and then get sarcastic.Last edited by Guest; 05-27-2011, 04:06 AM.
